Small update...
Took apart the puddle lights, its very easy to do now that I know how. At first I tried heat gun, then razor blade but nothing. I then saw through the lens that it has an internal ring. So last resort dremmel with those thin cheap cut off wheels. I melted the black housing all the way around, then used a small awl and popped the lens off. At first this was very hard, second light went very fast so its really easy now.
Here are some pics
Here is the cut and the lens popping out
Inside shot, note lens has plastic feet that pop down to help hold in bulb
LED installed, slight angle to shoot light away from door
Daytime view
I used super glue to put on the lens, and I will also go around the outside too just to make certain its all glued in. Im guessing the black housing is abs, and even though I have abs super glue I used the regular stuff because im not sure what the lens is made from.
Hopefully my dome lights show up soon
