Charge light flickers intermittently
Wahoo99a
Florida
My 01 5.4L charge light flickers intermittently at approx. 2000 rpm the charge light comes on and then goes off at approx. 2200 *or* 2400 rpm.
I replaced the belt thinking it might be slipping, but it continues to come on. The belt tensioner seems all right, How do you check them? It still takes a 24 inch breaker bar to move it. While I had the belt off I took the alternator to NAPA and had them bench test it, it tested ok. The battery is 2 months old.
Any ideas?
GRIP
hoboken,nj
check the connection behind the dash could be loose back there or the wires on the alt. might be loose.
W
Wahoo99a
Florida
Thanks. I checked the alt connections and everything seems ok there. I'll check the connection behind the dash later this week. I have to go back there anyway due my truck having the disappearing odometer trick hapening.
W
Wahoo99a
Florida
Well, I decided to take the truck to a local service place to have them check the alternator in the truck. Sure enough the regulator was bad. It was working intermittently, something the bench test couldn't find since it would only get the alt. spinning so fast. They charged me $20 to run the test. Then I hit the NAPA store and installed a new unit.
I do have one question though. This is the first time I got dielectric grease in the box with the alt. Is it actually needed with the connections?
Grasshopper
Moore, OK
I've heard both ways on dielectric grease...people who swear by it and those who could care less or recommend against it. I dunno...
I also have the disappearing odometer on my wife's truck. I just recently noticed it.
W
Wahoo99a
Florida
The odometer is next on my list right after the spark plugs.
tifanydire
