The clunk is both heard and felt.
I had seen that video before and I originally thought that it was the issue, but upon watching it was not moving in the same way that the video shows. It is moving more on the backside of that bracket which attaches to the differential.If you feel it like that likely not U-joints.
I'd recommend an inspection of the u-joints, yokes and transmission mounts looking for evidence of wear or missing bolts/nuts.
Ended up being the differential support bracket bolts which connect it to the differential. Re-torqued the bolts and sound is gone at least for now.
Thanks again for the advice
For the 2006 the spec is 100 ft/lbGlad to hear, what is the torque spec on those? I’ve had a mild clink for some time.
