david.bell.9678
- Joined
- Nov 27, 2014
- Posts
- 4
- Reaction score
- 0
Need some help please on a 2012 Expedition XLT 4wd - 203,000 miles
I bought this used at 24,000 miles and i believe this is the first code it has thrown since I have owned it. I replaced the camshaft position sensor and the light went off for a period of time. It seems to drive OK, meaning no engine hesitation, sputtering, etc.
After 3 - 4 days the Check Engine Light came back on and I had the code scanned again - same code again - P0394.
Here are my thoughts -
Bad sensor out of the box - doubtful
Over voltage [voltage spike] that is burning up the sensor
An intermittent wire problem, likely a worn or broken wire.
The guy at the auto parts store that did the scanning told me I could check for voltage using a multimeter, turn the key all the way on without starting the engine, and then check voltage on the connector. I did this but could not get any voltage to show. I did this on both Bank 1 and Bank 2 sensors. Same result for both, no voltage showing. Since the the Bank 1 sensor should be good, I assume I did something wrong.
Any ideas on how to proceed from here? Also what is my risk if I cannot get this resolved? Is engine damage a possibility?
I appreciate any and all thoughts/comments. I love this Expy and hope to put another 100K + on it.
Thanks,
Dave.
Thanks,
Dave.
