smo0othride
After reading this article about the myth of electric fans, I am skeptical if adding an electric fan is really any upgrade.The article is based on an RX-7 but I think the same concepts apply. Here are some excerpts from the article:
"What's important to note is that the fan is only used when the engine is idling, or the car is creeping along at low speed (less then 20 MPH)."
"There will be a horsepower gain for sure, on the order of 0.5 - 1HP. But remember that the electric power to run the fan must come from somewhere, and that somewhere is the alternator. Electric fans draw quite a lot of current. Most pull surges of 35A or more to start up, then run at 8A-10A. This puts extra load on the alternator. Ever pedaled a bicycle with a generator powered light? If so, then you will know that as the electrical load on a generator/alternator increases, the generator/alternator becomes harder to turn. Suddenly, all that "free" HP you just freed up is once again being used. This time, though, it is being used to turn the alternator. There is also an inefficiency in the whole system. We are converting mechanical energy, to electrical energy, to mechanical again to run the fan. This very inefficient, much less then just driving the fan directly via the mechanical energy of the rotating shaft. "
