Well - I discovered another symptoms that might help to trace the problem. Today was a huge rain, and everything was wet. Also a lot of humidity in the air.
I was driving heaving A4WD mode on. I started to hear 'relay clicking' and the lamp A4WD disappeared. Then, after 2 or 3 seconds, I heard another relay click and the lamps:
A4WD,
Fuel Reset,
4x4,
Low Range,
Low Wash,
started to be ON. After a second or two, they went off and everything was normal.
This sequence (flashing these lamps and clicking) repeated a few times in a few minutes..
Also - third thing happened.
While driving on D, R, 1 or 2- the drivers power window couldn't be lowered - action up was no problem, and in the same time the rear wiper, couldn't be enabled. BUT, on the gears P and N everything was normal (wiper and window was working good), AND if I enabled the rear wiper on N, and then changed to D and started driving, the wiper was still working!! and I could turn it off. Hoverer once turned off, I couldn't turn it back on, unless I changed the gear to N or P. This happened in the same time as that 'clicking/flashing' part. Now - all is ok and all is working as supposed to (except for that oil lamp - no change with that).
I know I have a problem probably with wiring or plugs, but - there is so much cables and connections, that I need some point to start - I do not want to rip a whole car apart
Many thanks once again
A4WD,
Fuel Reset,
4x4,
Low Range,
Low Wash,
