wardf
Well I changed the fuel pump and it still didn't come on. I tried it now before installing the pump in the tank and and reinstalling the assembly. so I checked voltage and I am only getting 6.6 volts to the pump. I have a knew battery and I get 12.6 V across the battery. I get 7.3 V at the relay #301 on the #85 pin. I kknow it is switching because I get voltage at the pump but where/why would I get a voltage drop at all? Where do I go to check now? Something that could have hurt it was that I used the 200 amp battery charger to try and start it before the battery was replaced. Is there something I could have burnt, everything seems to work except the fuel system. Thank you in advance.
