engine code p1151
Discussion in 'Transmission & Drive train' started by jrmustang, May 7, 2010.
  1. jrmustang
    jrmustang New Member
    Apr 16, 2010
    peebles ohio
    i have a 2000 ford expedition 5.4 and after doing a complete tune up (plug,wire,vac hose,filters and pvc)and put headers and dual exhaust on. i discovered that check engine light is either blown or unplug (bought at a used car dealer).so it was running funny, ran the codes and got P1151.i was wondering if an exhaust leak at the header to the down pipe before the first o2 sensor would cause this?
    I'm having a hard time getting the exhaust to seal up any info will
    help thanks
  2. tonydiv
    tonydiv technical advisor
    1,748
    127
    Sep 12, 2009
    Middle River, MD
    This is from obd-codes.com
    What does that mean?: A Heated Exhaust Oxygen (HO2S) sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
    Symptoms: You will likely not notice any drivability problems.
    Causes: A code P1151 may mean that one or more of the following has happened:
    Electrical:
    Short to VPWR in the harness or HO2S
    Water in the harness connector
    Open/shorted HO2S circuit
    Corrosion or poor mating terminals and wiring
    Damaged HO2S
    Damaged PCM
    Fuel System:
    Excessive fuel pressure
    Leaking/contaminated fuel injectors
    Leaking fuel pressure regulator
    Low fuel pressure or running out of fuel
    Vapor recovery system
    Induction System:
    Air leaks after the MAF
    Vacuum Leaks
    PCV system:
    Improperly seated engine oil dipstick
    EGR System:
    Leaking gasket
    Stuck EGR valve
    Leaking diaphragm or EVR
    Base Engine:
    Oil overfill
    Cam Timing
    Cylinder compression
    Exhaust leaks before or near the HO2S(s)
  3. jrmustang
    Apr 16, 2010
    peebles ohio
    it has been running rich, back firing, and hesitent in lower rpms im going to get the exhuast leak fixed this week and erease the codes. But how do i test the o2 censors to make sure they are sending the correct signal. what would be the next step that you would do?
  4. seeker
    seeker Full Access Members
    233
    Oct 14, 2009
    Acworth Ga
    I am not sure of any test that you can do on the o2 sensor. With that said, I have replaced my share of them. They fail and start to send a lean code to your computer. The computer adjustes to a richer fuel/air mix. This could explain your back firing. Change the o2 sensor. Visually check the wirring and connection. If it looks good, I am placing my bet that the o2 swap will correct you problem.
  5. jrmustang
    Apr 16, 2010
    peebles ohio
    that sound like the source of my problem i will have to work on it this week and will let you know if it was. I'm all most positive that's it. Thanks for the help
  6. Kamoflauj
    Kamoflauj New Member
    27
    Feb 10, 2017
    Rialto
  7. Kamoflauj
    27
    Feb 10, 2017
    Rialto
    Any luck on this code p1151 i have done a complete tuneup i would say bought from previous owner 00 expedition changed spark plugs coil packs maf sensor fuel filter air filter both upstream ho2 sensors air filter oil and transmission changed she runs fine except on idle just fills like a small sputter like it wants to die but evens out i would appreciate help i also recently ran so fuel injector cleaner for high mileage i currently have 328000 miles on a rebuilt at 210000 help im stumped
  8. Bedrck47
    Bedrck47 Full Access Members
    5,163
    476
    Jul 4, 2014
    Elizebethtown, PA
    Do you really expect a answer from the people on this thread? The thread was last posted on in May of 2010 Almost 7 years ago. And the last member to post on that thread hasn't been on the forum since then.
    I would suggest that you start a new thread concerning your problem and give as much details as you can
  9. stamp11127
    stamp11127 Super Moderator Staff Member
    60
    4,662
    530
    Mar 10, 2012
    Temple, Georgia
    Welcome to the site.
    Please note the date of the last reply before adding to a thread. In this case it is from 2010, and as usual there isn't a solution posted by the original poster.
    Start a new thread on your problem and include all info pertaining to the problem.
Share This Page
