Jack Snodgrass
I need some serious help with this problem.
I need to replace both the drivers side and passenger side for light assemblies. There are three (3) small screws that hold each housing in place ( two are on top one on the bottom ). The drivers side will come out with a little squeezing and reaching HOWEVER the passenger side is the issue. The top inboard screw is directly in front of the horn bell assembly. You can't reach the bolt holding the horns from the wheel well. Anyone ever do this job and if you did how the heck did you get to those top screws on the passenger side?? Help please.
