fog lights
MadTxn
You could rewire the switch or hardwire the bulbs to something with switched power in the fuse box. The switch would probably be easier. Just be sure that since you can have lights on without the engine running that you hook it up to something that's on only with the ignition.
AvroAero
Toronto, Ontario
If you have an 03+ that would be daytime running lights your thinking of. Some vehicles you can turn that on in the computer which a dealer would have to do for you. If not you need to wire it in or get someone to do it. Basically just go to the dealer and say you want daytime running lights on your truck.
LED domelights are ebay I'd say.
whoopassharley
Royal City, Wa
ya thanks for the info but theres an easier way. on my harley truck all i did was pull out the switch and spliced 2 wires and that was the easiest i need to find out witch 2 wires too splice on the sexpy
