BerndM
Today, with the engine off, transmission in Park, and Parking Brake set,I had ONE of the front tires lifted off the ground on my 2003 5.4V8 4WD EB.
As I was checking the brake rotor for thickness, I rotated the wheel forward and backward a bit and heard a very clear clunk sound coming from underneath.
My 4WD selector was in the normal 2WD position and the other front wheel was on the ground.
Would I be safe in assuming that this clunk sound is nothing more than just the expected gear lash in the front differential and other rotating components, or should I start sweating bullets??
I'd appreciate any input from you guys.
BTW...I did the same test on the other side and got the same results.
Thanks
Thanks
