06EXP
While replacing the control arms on the front of my '06 EB I tried to get the rotors off as part of the disassembly. No matter how much I tried they would not come off so I just left them on and took off the knuckle as a whole.
But as I am going to be replacing the rotors soon when I do a full brake job I want to make sure I get them off. I read while doing some searching that the 2WD has the rotors and hubs as an assembly and do not seperate. Is this true? This would be the first I've ever come across this.
I've also seen the video of using 1/2" bolts and nuts through the caliper bracket to get the rotors to pop off. If I can get confirmation that the rotors and hubs aren't a 1 piece assembly I will try harder to separate them.
