Do you have the correct bulb numbers for the turn signal, back up & tail light bulbsH8 FOG LIGHTS stock 35w
h9 65w lower HIGH BEAM headlight bulbs
hb3 60w 9005 LOW BEAM top headlight bulb
Those are the actual bulbs. Manual is wrong.
did you hook them up directly or get the antiflicker resistorsHeadlights in...its daytime but what a drastic difference it looks bright, how it shouldve been from jump the yellow halos were atrocious in any condition but sunlight...can't wait to see it at night in and in the rain, i wish i could put a led design like the factory ones but im hapoy with what i got...debating if i should put in the high beam bulbs later since the highbeams arent used often...shout out to dc man u came through with lbj clutchness with those bulb numbers
