Remember the transmission cooler connects to the A/C condenser in front and not to the radiator itself...that is why all trucks have the mount
Seams OP might have the "real life" answer to the "does the Expy HD radiator exist" question, since he should have received the unit by now...Any chance for an update?...Thanks!...Thanks. I've searched everything I could find her and everywhere else I could think. Sometimes the F150 site has good info for us Expy owners. Learned how to program the factory brake control module there. I just ordered the HD cooling radiator and will see if it will just be a swap. If anyone is interested I will post the results.
I looked at all the threads I could on the forum. Started with the factory brake controller and auxiliary transmission cooler installs which were fairly simple (need specific tools for the aux transmission cooler install in order to separate the tranny lines). I purchased the higher cooling capacity radiator but ended up paying a shop to do that install (not an easy swap). I’m still not sure if the radiator upgrade was worth it. When towing in high heat in AZ, the engine still gets warm and I need to take it easy on the big climbs. It was the same with the non-HD radiator but maybe it is better than it would have been. Either way, I tried to do everything I could to set the vehicle up for the max towing.
So you can answer the debate? The HD towing radiator exists, and is actually different?
