stamp11127
Your going to need the wiring diagrams first to study, then to plan the "attack".
You want to know where your going to tap into the harness before jumping in. If you don't you'll end up with a mess.
Butt connectors, to me, are not the way to go. Strip, tin, solder then heat shrink is the only professional way to do this. Think about it, do you see any butt connectors in the factory harness?
I'll try to look at this tonight for you.
Have you looked at what the current system is and how the connections were made? If you can get the wiring schematic for it you can use it as a guide for some of the connections or if the connections are proper tie into that harness since the wires are already there. But if "Bubba" installed it with masking or duct tape I'd redo the entire setup.
