Well ill give you the symptoms
-When problem occurs the speedometer goes out
-when problem occurs, the trans only holds first gear, I have to manually shift to second and thats all I have to work with
-Dash lights flash (4x4hi, 4x4lo, A4wd, low wash, and airbag)
I think it may be a speed sensor of sorts probably the one in the T-case, what are your thoughts?
