jaserlet
I recently bought a used 1999 Expedition 4WD with 150,000 miles. The pads were shot, rotor was beyond shot, and the front hub bearings are shot. I had no problem removing the caliper assembly but the rotor was rusted on to the hub. I found the nut/bolt trick on YouTube and used that to free the rotor. But now I'm stuck trying to remove the hub assembly. Everything has been soaking in PB Blaster for days and I still broke a 5 ton 3-jaw puller trying to pull the hub. I just got ahold of a 7 ton 2-jaw puller and tried cranking on that but only bent the hub a bit with no success. Help! I've never had so much trouble removing a hub before. I've read the threads on replacing the Expedition/Navigator/F150 hubs, and still can't seem to make any progress. Thank you in advance for ANY help!!
