Ok i posted about my 02 running rough. Well last night i got off work and started it up and it backfired under the hood well then it started running real rough. my check engine light came on so i took it and checked the codes it ran 8 different codes.
#s p0122 p1125 p0304 p0301 p0174 p0471 p1401 and p1000
two of them say they are tps sensor codes. two are problems with 1 and 4 cylinders. then there is one for the egr valve. I tride to replace the tps but when they did my motor swap they rounded out the bolt heads and didnt tell me they just said they replaced it. so im at a 4 way road with no idea witch way to go. should i try to fight with the bolts to change the tps and hope it works or would yall suggest trying something else first.
