0xowner
ah, good points... I was testing with lift gate open !
will try again with these considerations.
Check your wiring diagrams and you will find that there is only 1 pump in the reservoir The electrical circuit will reverse the positive voltage to the pump motor causing it to reverse direction. When the pump runs in one direction it provides fluid to the front and when the pump runs in the opposite direction it will provide fluid to the rear.
This applies to all 1st gen washer systems
