Is it starter/starter solenoid?
irishinontario
Brantford, ON
Went to leave wotk today abd turbed key,
Just a click, second time i turned the key, there wasn't even a click
The instrument panel, radio, a/c all worked and i tried boosting and still 1 click
Would it be the solenoid or starter and csn i get a link to replace
Thanks
stamp11127
Temple, Georgia
Would be nice to know what year vehicle you have since the wiring has changed from one generation to the next.....
Bedrck47
Elizebethtown, PA
Thanks
Now is the time to troubleshoot the problem and find the faulty part.
Rather than listening to those that will say its the solenoid or the starter and you end up replacing a part only to find out you replaced the wrong part.
stamp11127
Temple, Georgia
Reminds me of a "no start" I'm working on now. Except that his is an intermittent problem.
Preferred troubleshooting method:
Check the battery first - you need to establish that you have enough power to start the engine.
I'm going to assume that your starter relay is one of the 4/5 blade ISO relays used in the battery junction box on the later generations. If you have a test light or meter, check for voltage between 85 and ground and 86 and ground with the ign switch in "start". One of those should have power when the ign switch is turned to start. If it doesn't then you need the wiring diagrams and connector pinouts to start probing the circuits.
Common troubleshooting method:
Toss parts at the problem - eventually you will get it or run out of money.
relay
ignition switch
smart junction box
