MissileMech
Hello...I need some advice on how to tackle this problem. The left rear door will not open from the inside or outside. The lock actuator still works and I can move the lock knob up and down fully. When I pull the outside door handle it feels as though it is disconnected. The inside handle is still connected because when I pull it the door lock knob drops to the locked position. When I hold the door lock in the unlocked position and pull the inside handle the latch does not release.
Any ideas on what the issue may be? Has anyone removed the inside door panel with the door closed?
Thanks!
Thanks!
