Yes you can use a regular clamp. The replacement hose for mine i've been looking at from Autozone is just a standard hose with no "quick disconnect".
The trick to getting them off is to lift the little tab, and twist 45 degrees and pulling back. Sounds great but mine wouldn't budge. I had to cut the ring and slice the hose a bit to get it off. Hoping I have enough extra hose to cut the part I sliced off and put it on with a worm gear clamp.
