06 Expy
Hey all. My name is Daniel I have an 06 expedition eddie bauer 5.4 V8.
I replaced the engine in september of 22. The oil pan had a leak at the drain plug. Put a new pan on and now I'm trying to figure out 17 codes.
Found a burnt coil on cylinder 3. Replaced, found the cylinder temp sensor wires on the plug were bad as well as a knock sensor. Replaced both knock sensors and temp sensor plug. I pulled the intake Plenum to check them harness for any bad wires. Decided to replace the engine harness and transmission harness. Thought the may have been pinched from jacking the engine up a little to get the oil pan out. Ran horrible ever since. Went into fail safe mode and the o/d off light is flashing. have the following codes
P0010
P0020
P0102
P0135
P0141
P0155
P0161
P0443
P0446
P0740
P0743
P0748
P0755
P0758
P0962
P1000
P2106
All help is greatly appreciated. Thank you all in advance.
P0010
P0020
P0102
P0135
P0141
P0155
P0161
P0443
P0446
P0740
P0743
P0748
P0755
P0758
P0962
P1000
P2106
