First snow and first time trying to use 4x4 since last year and it didn’t do crap. No codes, says it’s in 4x4. I haven’t used it in anything serious since I dropped the tranfer case off for the torque converter job so everything was disconnected. Vacuum system is working correctly on command. Hmmmm wonder if it’s electrical or hard parts related. Everything is attached and plugged in. I thought I heard the shift motor working but I’ll catch closer tonight. I’ll update as we go. Symptoms are only 2WD when in 4x4 high or low range. No 4WD anywhere. No codes or bad lights on dash and truck thinks all is well...
