MOVED: New member from Michigan
Grasmuss3
Muskegon, MI
Hey all, Gary here from Michigan. I recently purchased a 2012 Expedition and love all the features. Except one, the rain sensing intermittent wipers. They dont work. Low speed and high speed wiper works fine. When I choose one of the intermittent settings, I get one swipe and then never again until I click up to the next higher setting. Is there possibly a setting that enables the rain sensing?
Mediamonkey11
Super Moderator
Super Moderator
Enumclaw, WA
Moved here instead of the New Member Check in section, hopefully you'll get the help you need here!
I will say that I had to enable the rain sensing wipers in the vehicles user interface area as well as select them on the stalk, seem to work quite well! But, I'm not sure if there's a difference between 3rd and 4th gen setups there...
Mmart
Philadelphia
I have to ask the simple question first? How much is it raining when you use the intermittent wipers? I did the same thing with my 2010 when I first got it. It was drizzling and I turned them on and it would wipe once, I turned it up a notch and it did the same thing so I just moved them to the first “constant” speed. When I finally got around to looking into the problem I came to find that when you switch through the intermittent settings, you’re not controlling the time between each wipe, you’re controlling the sensitivity of the sensor. So no matter what you set it at it will only activate based on how much water(or whatever) is on the windshield.
twodollars
I disabled that on my 2013. Just disconnected the connector to the sensor, then you have full control over wipers. The auto feature rarely seemed to get it right for me. Either too slow or running at high speed.
