Nokturnal
Well I bought this Expedition and the last few days I've been trying to get the motor all tuned up and running nicely. What I've done so far (maintenance wise)
Cleaned throttle body and all ports in it and the elbow
Had a 2 step machine fuel system clean done
Oil Changed
Seafoamed twice (using brake booster)
Spark plugs/wires changed
New battery terminals
Cleaned MAF sensor a little bit (didn't remove it, just sprayed it the best I could without taking it all apart)
Changed Rear Diff Fluid
Replaced Both Coil
Gotts Mod W/New Filter
Changed Fuel Filter
Cleaned IAC and Changed Gasket
Will be doing soon..
Transmission flush
Checking Fuel Pump
Will be doing within the next 6 months..
New exhaust system and cat
Programmer
The motor has 210,000 on it. Just looking for recommendations for things to check or do to get the motor running stronger, smoother, and more reliable. Anything to help with gas mileage is a plus also. Anything will help me out.
Thanks guys.
Oil Changed
Replaced Both Coil
Changed Fuel Filter
Transmission flush
Checking Fuel Pump
Programmer
Thanks guys.
