No aux audio input on 2017 Limited with sync3?!
17LimitedExpy
TN
FORSCAN can change that.
Loki,
Have you found a code for the Powerpoint Timeout on the 2015-2017? Please share if you know how we can adjust the timeout of the 12v outlets.
I have the code for the 2018s on our FORScan spreadsheet.
Thanks.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Loki,
Have you found a code for the Powerpoint Timeout on the 2015-2017? Please share is you know how we can adjust the timeout of the 12v outlets.
Thanks.
I thought I had. I will get a hold of the Expy from the wife later this week and confirm.
-Ray
17LimitedExpy
TN
I don't see it on my 2017 spreadsheets. Which setting is it on the 2018? I have a dump of the As Built module data for my truck but it's all in hexadecimal.
-- Chuck
On the 2018 sheet, look for the ‘PowerPoint Timeout’
chuck s
Anyone tried the 2018 setting on a 2017?
It's apparently at address 726-39-01 where my 2017 "as built" is 0101 0069 ~~~~ where ~ is "ain't there."
After a battle with the spreadsheet (needs to be downloaded to actually read it) it appears the no timeout setting for 2018 "could" be.
original: 726-39-01 ???? x?xx xxxx
modified: 726-39-01 0000 x1xx xxxx
but that doesn't mesh with the data I have for my 2017 which has an infinite time out (meaning it stays on until the battery is physically dead).
-- Chuck
