Not turning over with key
Discussion in '1st Gen - 1997 - 2002' started by AaronMoss72, Jul 17, 2017.
  1. AaronMoss72
    AaronMoss72 Member
    45
    13
    Jul 17, 2017
    Western NC
    Yes, i will download one. Thanks!
  2. Bedrck47
    Bedrck47 Full Access Members
    5,419
    533
    Jul 4, 2014
    Elizebethtown, PA
    Copied from the 1997 Ford Factory Service Manual
  3. AaronMoss72
    AaronMoss72 Member
    45
    13
    Jul 17, 2017
    Western NC
    Awesome Bedrck47, thank you very much!
  4. Bedrck47
    5,419
    533
    Jul 4, 2014
    Elizebethtown, PA
    You should have 12+ volts at the tan/red wire on the starter motor relay when you turn the key to start
    AaronMoss72 likes this.
  5. AaronMoss72
    AaronMoss72 Member
    45
    13
    Jul 17, 2017
    Western NC
    Thanks again Bedrck47 you have been really helpful! I will let you know what i find out.
  6. terryb99
    terryb99 New Member
    Nov 30, 2011
    Seattle
    I believe you are over thinking this.
    If you jumper the solenoid and it starts and runs, replace the solenoid. It is cheap, easy, and about a 90% chance of fixing the problem.
    Terry
  7. Bedrck47
    5,419
    533
    Jul 4, 2014
    Elizebethtown, PA
    Nothing is being over thought Although I do agree that it MAY be a bad solenoid But I would rather know for sure that the solenoid is getting the correct voltage to energize rather that just replacing the solenoid and then find out It wasn't getting enough voltage to energize.
    Had the OP stated that he heard a click when he tried to start that would tell a different story But he didn't state that.
    Plus I would rather be 100 % certain rather than "about a 90% chance of fixing the problem" by tossing a part into it. You may be correct but that 10% may bite you in the a$$
    Get involved in this forum since this is your first post since you became a member 6 years ago.
  8. rjdelp7
    rjdelp7 Full Access Members
    457
    82
    Nov 30, 2014
    NY
    Check your theft light for rapid blinking, when starting. Try a different key. Don't power lock doors, with key in ignition and driver door open. Try starting, with gear shift in "N".
  9. AaronMoss72
    AaronMoss72 Member
    45
    13
    Jul 17, 2017
    Western NC
    Hi everyone, sorry it took so long to get back. Updates, cleaned all contacts, not anti-theft, fuse for starter relay keeps blowing. I can start it a couple times then it blows. Guessing something is grounding out... Would the solenoid cause this?
  10. AaronMoss72
    AaronMoss72 Member
    45
    13
    Jul 17, 2017
    Western NC
Share This Page
