Phone keeps disconnecting!
iamhollyb
Dallas, TX
My phone worked great with my 2014 King Ranch edition until this morning. Took a call from my husband on the way to my daughter's school, she hopped out with her iPod touch and disconnected it from my truck (Bluetooth) and the very next call I took wouldn't work with my Sync. I have an iPhone 6 and have never had this problem before.
I have turned the truck off and on, deleted the device a few times, turned Bluetooth off and on, done some kind of reboot, and it will connect for a second then I get "Bluetooth disconnected" and "no paired phone found" before it disconnects again.
Help?!
I
iamhollyb
Dallas, TX
Also, I can still play podcasts from my phone through the stereo, which seems weird to me. Just no phone service.
FordIVTteam
Dearborn, MI
stamp11127
Temple, Georgia
I'm impressed with the blue oval team. This is the first time they have responded with a real "how to" instead of take it to your local dealer.
5 "Ata boys" for them!
FisherPete
Portland, Oregon
After several years of flawless blue tooth connection, my Droid Maxx has been having trouble over the last couple weeks. It only pairs about 1/2 the time. It's great to have some tips to see if I can improve it. Typically I don't notice that I'm not paired until the phone rings and isn't coming through the SYNC. I'm going to try a clean pairing and if that doesn't help I'll try the Master Reset. Frustrating that it's intermittent, but whaddya do?
I
iamhollyb
Dallas, TX
Well shoot. I turned everything off (phone, car) and let it sit for a bit then turned it all back on. Turned Bluetooth off and back on. Tried to delete my phone from my Sync, and it just won't go away. Performed a Master Reset and my phone still shows up.
I deleted Sync from my phone and then re-connected it. And it worked for a few seconds. Then it disconnects again on the Expy side and says no paired phones found. Ugh.
dlcorbett
tx
I had the same problem with my truck. I didnt know what to do as i turned off my phone and all but nothin worked. What i did was disconnect all bt devices. I then cleaned my cache to my phone and did a hard reset on it, do not just turn the phone on and off as the hard reset updates your phone, not the powering off of the phone. My phone was a bit older so it needed to be done anyway but a hard reset needs to be done on all phones atleast once per wk. After that i connected again and since have not had a repeat problem.
I
iamhollyb
Dallas, TX
I can't get my truck to delete my phone. I got it to delete my daughter's iPod. But my phone continues to show up. And by hard reset on the phone, do you mean the power and front button at the same time until it restarts?
k9education
It never hurts to do a hard reset and sometimes it's necessary, but if you have to do it that often there's another issue with the phone. I do a hard reset on my iPhone 5S once every 1-2 months and have no issues with it in the interim.
Anyway, +1 on the hard reset for this particular issue. Remove the device, shut the vehicle off, hard reset the phone, and try to re-add it.
