juan214
Hey guys,
New mystery, while driving home yesterday from hospital. Truck acted up with an acceleration problem. It would not even get up to 1 MPH floored it same issue. Pulled over the truck had no power (no lights nothing while at idle it made a click then died. Tried to crank it just clicked. Pulled battery left truck for a tow (1 hour plus wait). Dropped it off at Advanve Auto Parts for a full charge. Had it tested they said it was good. Put battery in last night, tried to start it it just clicked then left it disconnected over night. Today, reconnected the battery same thing just clicked. Check voltage it said 11.72. Saw the engine turned (so not seized). Jumped and charge it with cables, it started right up. It idled a little rough until it caught up. Let it idle for 15 to relearn idle. Drove around the block and ran like it normally does. Truck starts with no issues now but need to figure out the cause.
Prior Issues:
Any help is appreciated. Thanks in advance
I did get some of my own info my scanner.... I'm holding the first image suspect
Prior Issues:
- Had a knock after A?C repairs. Not engine or compressor sounds like tranny. Posted here previously. Seems to may cleared after sitting five months.
- I can feel like it has a misfire but with CEL or codes.
- I'll drive it seems ok except for a my suspect misfire. when it comes to a stop seems like a transmission downshift then idle changes drastically to rough.
- Still drivable
