Rear subwoofer
Hampton, VA
The JL Audio stealthbox will fit but I think it's a 10"...it's identified to fit in the EL but it will fit in 2nd gens
Mr. 10K
whitelightning99
Pa
Well idk if there's a replacement box but i got one 12 hooked up to the stock system "mach" and it bumps pretty good better then i expected it to and it's all i need and want
Red92lx
3rd rock from the sun
I went though a lot of trouble trying to use the stock sub and discovered it was much easier to just run a new wire to a powered sub. The factory stuff is super weak and even if you got a 12 to fit, you would need a real amp for it too work like it should. Stock amp is less them 40 watts.
