rtbrjason
Truck had a compustar CS600 start unit in it when I bought it. It's been working fine for a few years.
Recently, I did a stereo/backup cam install and while I had a lot of the dash off for paint, replaced a few pieces. After putting it all back together, the remote start doesn't work. It cranks but no start. If I put the key in the ignition and remote start it, it does work.
There doesn't appear to be a bypass module. What I found , was a spare key under the dash with just a wire wrapped around, and tapped to it. Each end of the wire goes to a relay, and the rest of the wire looped up somewhere. I think it might have gone under the steering column, as I did replace the steering wheel shroud. It appears to remotely transmit the signal from the key through the wire to somewhere.
Any ideas on this? I've tried looping the wire around the ignition, near the pats, near the bcm etc.. It's just a loop of wire coming from the key, no connection but I think it had to be near something specific to make it fire up.
I hate to have to buy a new starter and bypass module.
