Grey ghost
Why don't they make a raptor expedition? That would be wild.lol
Expy FX4 skids bolt up on non FX4 Expy models.
While I don’t know about the FX4 air dam, I’m sure it does move about a bit. I added a skid plate to the front; the lower fascia left rub marks on the skid plate from some obvious movement (lower fascia was in contact with the skid plate after solidly mounting plate).After reading the above, and the comment about the lower bumper fascia being a little floppy with the air dam removed, I wonder if the Expy FX4 air dam, with the higher center clearance, is compatible with non-FX4 Expys. Anyone happen to know?
Thanks,
Dan
You could probably cut down the air dam to almost nothing, and retain the rigidity.
Ha ha! I thought I'd seen that somewhere!Refer to post #5 in this thread to see what the front air dam looks like when cut down to about 1" while still maintaining the rigidity of the front lower facia.
Apparently, it’s a 5.5mm according to some instructions I had. I used a 7/32” (which is most likely the size). That size is also used for the fender liner on the inside of the wheel arch - same screws used on the fender liner.I must be an idiot because I can’t figure out what size bolt head the small ones are. 5mm is too small 6mm is too big. Same with 1/4” and 3/16”. Also do the white clips need to be removed?
