removing spark plugs
Buck Nasty
Oregon
I too would like to know. I'm about ready to take the plunge and do it myself. So I take it you got the front six? Did you use a "swivel", u-joint, etc to get the 3rd pair or just a plain old ratchet?
Rumor has it you may have to remove the fuel rails to get to those plugs. I wonder if there's a way around it or if removing/re-installing the rails is easy?
mustangswan
seattle
I use a spark plug socket with a u-joint then a 2 inch ext with another u-joint and another long ext then the wrench. You do not have to remove the fuel rail. They are not that easy, but very do-able.
green03
College Station, TX
i would make sure and blow compressed air into the hole to get any dirt out before pulling the plugs. I go a step further and fill the holes with brake cleaner then blow out with compressed air followed by a little penetrating oil to soak for 20 minutes to make sure the plugs come out smoothly.....
Matt R
Buck Nasty
Oregon
Good tips Matt...Thanks!
.....huh, huh.....he said penetrating. Sorry, I couldn't resist.
2002EB
Florida
I've replaced countless plugs in 4.6 and 5.4's and never pulled a fuel rail. P/S reservoir yes, rail no.
It's easier on the 4.6 it seems.
E
ericnj75
neptune city new jersey
today i chose to clean the thottle body so i took it off to clean it. so i changed the plugs while i had it off. man it made life so much easier. took me less then 1 hour to change the plugs,wires and the coils. thank you guys for all your help.
Staff online
Wolf_Lazarus
