Having intermittent screeching at start
Long story long. I bought an 03 EB 4.6L with 119k miles. It was in decent shape for the age and I figured I could fix any issues. I hope I am not wrong.
So a few days in the starter made a horrid noise and was like a loud screeching grind. I climbed under and the starter was loose, as in I could wobble it by hand. I ended up removing it to examining it and found there were only 2 bolts, the third top bolt was missing. I ordered the special bolt from Ford and the other 2 "normal" bolts. I figured why not get all new bolts. I then bought a starter on Amazon for pretty cheap, it had good ratings. I plug it in get everything going and great! Until....
About every 25th start it would make this screeching and not start. No clicking, power everywhere. No dim lights or anything. I ended up crawling under and banging on it and it started up another 20 times in a row then the screeching happened again and it didn't start until I took the key out and tried again. I replaced the battery and wire brushed the contacts and it seemed to help. Now its doing it again and its driving me crazy. When it starts, it starts strong and no issues. When replacing the battery I changed the order of the power cables on the battery terminal and it seems to affect the frequency of the screeching. It varies from 1 out of 5 starts to 1 out of 40 starts. But as soon as I think I have it knocked out, it comes back to bite me.
I really do not think its the starter, I think its some electrical gremlins. When the issue happens, if I let the system "boot up" as in the radio come on and all that it will start usually the second time. Sometimes it takes 3 tries. (without having to go under and tap on anything) My next plan is to systematically try and check all the grounds and see if I can find anything. One other note, I could not arc across and get a spark on the starter. Does that mean maybe the starter relay isnt working? Where is the starter relay on the 2003 4.6L?
Rambling on. If anyone has any ideas please let me know. I can swap a starter but that would be my last option.
Thanks
