service engine soon light came on...
Discussion in '1st Gen - 1997 - 2002' started by AaronLG, Jul 12, 2011.
  1. AaronLG
    AaronLG Full Access Members
    436
    Jan 16, 2010
    Lubbock
    what would cause this? how do I diagnose the issue? can they check the code or is it something different since it's not the check engine light? I think it came on about the time I did my exhaust but it went a way for a while.
  2. Canadian Expy
    Canadian Expy Full Access Members
    3,039
    139
    Jul 16, 2010
    Toronto ON
    yeah you should be able to scan for codes, what did you do to the exhaust?? Did it cause O2 sensor to throw a code?
  3. Explor2Exped
    Explor2Exped Full Access Members
    31
    701
    Mar 29, 2011
    Nashville, TN
    Did you check for codes?
  4. AaronLG
    436
    Jan 16, 2010
    Lubbock
    Haven't checked for codes, that's another issue, fuse for port keeps popping. had the rear cat removed, didn't think there is a O2 on it. maybe that's the issue.
  5. Canadian Expy
    3,039
    139
    Jul 16, 2010
    Toronto ON
    If you removed the rear cat that can throw codes. did you put a new front cat on? you can get away with a single cat if the new front cat can handle all the extra pollution. Also there is a rear O2 that if put in the wrong place, distance from the cat it can also throw codes. How do you like the rear cat delete?? I want to do that badly:drool2: but not sure what new cat to get? so I don't throw codes. Magnaflow makes some but unsure which model to get???:shrug:
  6. AaronLG
    436
    Jan 16, 2010
    Lubbock
    Gave it more sound for sure. Haven't noticed much of anything else. Would a programer be able to clear it?
  7. KWT2000
    KWT2000 Full Access Members
    2,376
    34
    Feb 4, 2010
    NINE MILE FALLS
    make sure the rear 02 sensors are plugged in... i am still running the stock front cats with the rears gone and no problems...
    but also your front cats could be bad...
    with that fuse popping it could be a different porblem all together
  8. Canadian Expy
    3,039
    139
    Jul 16, 2010
    Toronto ON
    I know my Edge reads and clears codes
  9. walnuts4x4
    walnuts4x4 Supporting Member Supporting Member
    34
    6,471
    Jun 18, 2009
    Watertown, NY
    +1 for edge clearing codes.... and no problems for rear cat delete....
  10. Tigster
    Tigster Full Access Members
    220
    Oct 30, 2010
    Florida
    any auto parts store will pull the codes for free so you can see what it is first.
Share This Page
