service engine soon light came on...
AaronLG
Lubbock
what would cause this? how do I diagnose the issue? can they check the code or is it something different since it's not the check engine light? I think it came on about the time I did my exhaust but it went a way for a while.
Canadian Expy
Toronto ON
yeah you should be able to scan for codes, what did you do to the exhaust?? Did it cause O2 sensor to throw a code?
AaronLG
AaronLG
Lubbock
Haven't checked for codes, that's another issue, fuse for port keeps popping. had the rear cat removed, didn't think there is a O2 on it. maybe that's the issue.
Canadian Expy
Toronto ON
If you removed the rear cat that can throw codes. did you put a new front cat on? you can get away with a single cat if the new front cat can handle all the extra pollution. Also there is a rear O2 that if put in the wrong place, distance from the cat it can also throw codes. How do you like the rear cat delete?? I want to do that badly:drool2: but not sure what new cat to get? so I don't throw codes. Magnaflow makes some but unsure which model to get???:shrug:
AaronLG
AaronLG
Lubbock
Gave it more sound for sure. Haven't noticed much of anything else. Would a programer be able to clear it?
KWT2000
NINE MILE FALLS
make sure the rear 02 sensors are plugged in... i am still running the stock front cats with the rears gone and no problems...
but also your front cats could be bad...
with that fuse popping it could be a different porblem all together
Tigster
Florida
any auto parts store will pull the codes for free so you can see what it is first.
sharprd65
