okiranger
Hey guys, I'm doing my brakes myself for the first time and will be taking the rotors(about 18mo old) to get resurfaced. I noticed what looked like a set screw on the rotor but nothing in my Haynes manual refers to taking this out. Is it really a set screw or will I not have an issue? The manual states that the 4x4 models calipers should just pop off once I remove the caliper mount. Also, I'm seeing conflicting info stating the front caliper Allen wrench is a 9mm and the back is a 7mm, can someone with the same truck confirm? Also, what size are the large bolts that hold the caliper mount on? As if I hadn't already asked enough in one single post, can someone confirm the torque rating of the above referenced bolts, and if they require locktite?
I'm a bit apprehensive of the job but I've bought my first house recently and I need to save a bit of money and start doing my own maintenance work.
