Spacer Lift Questions
AlexNorton74
AlexNorton74
Bama
I'm currently saving for tires now. I'd love to try and get a 33 or 35 if possible on the stock wheels. I've been searching for a thread with more info on this but I'm coming up empty. I'd love new wheels too but that's out of the question for now. Tires I currently have are very worn and need replacing asap lol.
woodsbum
New Jersey
I am currently waiting on my F250 to get out of the shop, then the Expedition is going in for tires. I am thinking about 33x10.5 right now- to get the height, and hopefully still use stock rims. If I don't hear or see any other posts, Ill take some photos of mine when its done and let you know.
AlexNorton74
AlexNorton74
Bama
Sounds good!! What kind of tires you thinking about going with?
woodsbum
New Jersey
I was going to get General AT2s, but after checking I don't think they make a 33x10.5....
woodsbum
New Jersey
View media item 6297View media item 6296
Update. Not enough photos- got too frustrated to take any more. Had a heck of a time with the tie rod end and the sway bar/stabilizer end links. Both had those silly studs with a 10mm hex to keep them from spinning. Which strips immediately when you start putting pressure on the much larger nuts that hold these together. Needless to say I had to cut off both nuts on the driver side because they froze up and the 10mm stud stripped. I was able to use a pipe wrench and vise grips, and a combination of curse words that will forever hang in the ether above my neighbors garage to get them off the passenger side.
Now I am having to find replacements for these two nuts. I found one online- the M16-2.0 Flange Nylon Lock Nut that is used for the sway bar linkage. But I have had no luck finding the tie rod end nut- a M14-2.0 Freespinning Flange Nylon Lock Nut. I may just have to buy the tie rod end simply to get this specific nut. Unless anyone has any ideas as to if I could use a standard nylon lock w a washer? Or a standard flange lock nut? Though I suppose that they would have used this ridiculously obscure fastener if they did not have to.
Long and short- I was able to get passenger side front done, w/ the new tire on. The driver side front is back together, but waiting for these two nuts to be completed and tire to be put on. I used a jack to support the lower control arm which I unbolted from the frame and allowed to drop down out of the way. This is what the 'instructions' indicated that I received when I purchased the 3/2 lift off of ebay. I use that word loosely because they hardly constitute comprehensive instructions in any way. There is a huge learning curve, that includes cutting those nuts off to start so as not to damage the linkages.
On the positive side, you can see in the photo- I found a great deal on a set of stock tires off a newer ford. They are 295/70R18s on great looking rims with gray accents just like my truck. They will look great when I get this giant headache sorted out.
I suppose if you want to run with the big dogs, you can't piss like a puppy. I will update with more photos soon.
woodsbum
New Jersey
Well, after yet another Saturday, and part of a Sunday we are complete and finished. Lets start at the beginning- or rather the rears.
I finished up the fronts last Saturday, but realized the drivers Swaybar link threads were all buggered. Not good. So I got it back together enough that it would hold, put a tire on it, and decided I would go back to it to finish after I got the rears done. Jacked up that a$$ end and got her in jack stands. Took tires off and sprayed everything down with a liberal coating of PB blaster. I did this twice more before....
This Saturday, when I planned to try to rear spacers. The directions for the rears- loosen the control arm bolts, take off the tie rod end, and take out the lower strut bolt. Seems simple. And it WAS! I was able to get them off easily, and back on with out any major issues. By myself to boot. I did have to manhandle the whole assembly to re-insert the lower strut bolt. It took a long pipe, a foot to push in, and a long arm to insert the bolt. As a side note- do not hammer this bolt back in- you WILL bugger the threads. I did this the first time, but realized it before the point of no return. Took the bolt off and was able to fix the damaged threads with a small triangle file. The second time, I made sure that the bolt went in easily, which is not an easy task by yourself. In any case, I was able to get everything back together with out and major issues. Great- now I just have to get back to that sway bar linkage.
That't the hard one- the inner strut mounting nut on top- if you have big hands good luck getting in there.....
View media item 6306View media item 6305
These are easy...
View media item 6304
Just some other work photos of the rear....
View media item 6303View media item 6302View media item 6301View media item 6300View media item 6299
Also- those little blue Ford symbols ARE center caps!
View media item 6298
Located an Advance Auto that had Moog sway bar ends, and picked them up. Went back to the truck Saturday afternoon. Swapped jack stands, front tire off, and got the new link in on that side. It was a task- and needed to be cut off. The lower ball joint is through the lower control arm- which has a recessed hole for the nut. This means no way you can get a 10mm on that stud as well as turn the lock nut off. I was prepared and used a angle grinder and cutoff wheel to cut the sway linkage off the ball joint. Then put a pipe wrench on the little ball from the ball joint and turned out the nut easily. The install on the new linkage was very straight forward, and the new ones have a spot for an 18mm wrench to hold instead of that ridiculous 10mm stud. Pause here till Sunday.
Sunday I went back over to do the passenger sway link- figured I should replace in pairs. Anyway, this one was the same process as the first. Everything went well - no major issues, except I hit my knuckle with the dang grinder. Had it in my right hand as I sat up from laying under truck, and guess my left hand was in the way. Lucky it was already off, and just spinning as I sat up or it would have been much worse.
Now its Monday morning- and the truck is in the shop getting an alignment. It was pretty wonky when driving over to the shop- felt like it was falling left or right trying to steer. Hopefully this is a result of the alignment being off, rather then something I missed in the install. Waiting to hear from the shop to see how bad I f-ed things up with my front end.
That folks is where I am at with this saga. All for a slightly better looking stance..... haha
Seriously though, the truck looks awesome with the 295/70r18 tires.
View media item 6307View media item 6308View media item 6309
waleedalmadani
