Maybe someone can help me. I have a 97 expedition and when i turn the ignition switch to start, all i hear is the starter relay clicking and not the starter solenoid. My door locks lock and unlock automaticly. I thought it was the battery......I had it tested under load and they said it was good. I also checked to see if i had voltage to the starter solenoid when the ignition switch is turned to start..........I have voltage there. I assumed it was the starter so i removed it and had it benched tested and they said it worked.
I am now at a loss and havent tested any thing else. Can any help me or give me some insight on this........thanks
You did not mention where on the starter solenoid or which wire of the 3. Make sure you are testing from ground to terminal.
One large terminal should have 12v+ at all times.
The small wire is from the ignition switch which only has voltage while the key is in crank position. This should activate the solenoid completing the contacts giving 12v + on the load side (other large terminal). But its important to check for
voltage drop here as key is turned to crank position. This will determine the condition of the contacts or wires leading up to this point.
The starter solenoid is a very high amperage relay in which the contacts can build up resistance over time due to carbon build up from arcing. Enough resistance from here or elsewhere and you will not have sufficient power to crank starter over.
If voltage drop is indicated then you will have to test multiple points to figure out exactly what point it is coming from.
It can be battery, wires, connectors, grounds, solenoid, etc....
