jruppert
I am experiencing some issues that I will need to address when spring comes around. I have a clatter at start up. It lasts roughly 2 seconds, then clears up. I have been experiencing some cam phaser issues as well. There is also a horrendous exhaust leak at both manifolds.
So that being said, my thoughts were to purchase new chain guides, tensioners, oil pump, water pump, possibly new chains as well. While the front is torn off engine, I thought I should replace the exhaust gaskets. I have quite a bit of concerns with the studs for these manifolds as I believe some will be broken. I have come to the conclusion that removing the heads might be easier seeings that I will have valve covers off with timing cover off to fix my chain issues. Oh.. forgot that I plan on replacing the phasers as well. I should also mention that the truck has 198,000 miles currently and does not use oil.
So my thoughts were, if I have to pull the heads to fix any studs, do I really want to replace manifolds with factory (since they will be warped most likely) or go aftermarket? Also, if I am going as far as I am going, I thought about upgrading the cams. I see Comp Cam has the SPR cams which require replacement of springs and locking phasers. If I have to replace the phasers, can I just lock them instead or do you need to have a fully functional phaser for the lock to work? What I notice any improvements with what I mentioned or should I go further? Just thought I would get you guys .02.
Thanks!
Thanks!
