Throttle Body replacement-oil film
cmc3
Florida
I was getting the engine limp mode problem described in other posts.
I removed the throttle body and cleaned it with carburetor cleaner, and WD-40 for all the moving pieces.
This fix worked great for about 2K miles. Then I got the wrench & limp mode out on the highway.
This time I replaced the throttle body.
While inspecting the old part I noticed a light deposit of oil on the inside bottom half of the flapper valve. Is this normal? (2017 XLT 100k miles)
JasonH
Houston, TX
Mine had the same issue around the same mileage. Catch can would probably help here, if you plan on keeping the vehicle for awhile.
cmc3
cmc3
Florida
Going to keep it until it's a worn out rusted hulk.
At 100k I still need to drive with the window down so I don't gag on the new car smell.
