Timing chain
Ales Kartal
Czech Republic - Prague
Hi, please sorry for my english. I have question, my expedition have now 100.000 miles. Engine sometimes yellow reports errors "check engine" Timing chain is noisy. Please when it is time to replace chain and Cam Phaser ???
Spark plugs, fuel ,filters is ok
Im second owner know the repair work done in the past.
Thank you for help
Best regards
kwod8832
Charlotte, NC
I might be wrong but I don't think you replace a timing chain. If it was a timing belt then you would replace it. Like I said I could be wrong.
Temple, Georgia
There are videos on youtube about changing the timing chains and cam phasers. How readily can you get parts for these over there? Cam phasers are pretty expensive from what I remember.
Timing chains and guides do wear, so they are a maintenance item.
FYI - your English isn't bad
mystik
If the timing chain is making noise, then you change it, it intales replacing the chain guide rails, tensioners & 2 chains. Also you must check the sprockets to make sure none of the teeth are broken. You must check for any metal dropping in the oil pan. Ive done these, its really not an easy job, if you are not a mechanic do not try this on your own.
