ciliatus
I have an 04 Expedition XLT 4WD. Driving forward has no issues at all. When I put in reverse, it is fine as well, until I hit the brakes. It is not immediate unless I hit it hard. ie... If I am trying to back slowly, with slight pressure on the brake pedal, it will go for a bit, but then I get a thud and feels like it locked. If I let off of the brakes, it still feels locked, and is almost like a metal to metal grind. If I place back into Drive, my brakes feel a bit loose at first until I basically pump them back up. then everything is fine again.
I thought maybe there was an issue with my back disc pads, so I replaced those. While doing so I also pulled off the rotors and looked at the emergency brakes. I did not see anything that stood out to be the issue. Put everything back together, took it for a drive and still exactly the same thing.
The issue started out slightly and originally when I was backing I would just hear a small thud, but still backed fine. If I backed slowly while some pressure on the brake for about 5 ft or so, then it was fine after that and if I hit the brakes harder, it would not make a thud or anything just stop normally. Now it feels like when it makes that thud, something is binding.
