IMINYOURCHAIR
About to lift the engine block off the trans to get the oil pan off to replace the p/u tube and pump. I will be able to get at the torque converter to remove it too because it has the shudder from the front of the truck. same as many of the threads I looked at that ended up replacing it for the fix.
good news is these are the last parts to remove before I get to start putting things back on.
