lunchboxlust
Well yesterday it was -4 out got up and the heat in the house stopped working and the water-heater sprung a leak. Didn't freeze but a fitting failed. So off tho the parts store.
But wait my car wont go into gear. I figured the shift cable fell off again. Sense it was so cold I called a mechanic I know that would do anything for a 6 pack to crawl under it to put it back on. Well it wasn't off. I hop in it and It kind of goes into gear. Reminded me of driving a standard for the first time where I had to feather the gas and hold the rps to get it to go into gear. Does this in drive and reverse but worse in drive. For the last few months it had a hard time going into 4th when cold. it would hold high rpm for a minute or two but once it shifted once it would be fine for the rest of the time
Fluid level is fine took it for a drive. Once I get past 30 mph it is fine but below that it slips out of gear. Its not violent or anything but at a stop light if I have to stop its almost impossible to catch a the light.
No check engine lights or anything 190000 miles on it. Looking to see if this is a common issue that I can fix without a rebuild or junk yard trans for the moment because its so cold and I don't have a lot of $ kicking around after the holidays. I think its a 4r100 but haven't confirmed. As always any info would be great. Thanks
