Transfer Case Vent Valve?
Drae
Anchorage AK
I'm having the hardest time finding this part that screws into the transfer case. It is towards the top left on the front side of the transfer case looking from the front of the vehicle to the back. In the picture it's removed but you can see the threaded hole. A hose connects to it but was damaged and knocked off during the carnage. It's a part that should never need replacing but the front driveshaft on my 03 5.4 broke off the back u joint and mangled a few things like the MLPS, shifter cable, bent (what I believe to be) fuel lines, drive shaft cover and this vent. Any help finding a part number, the actual name or picture of how the part looks undamaged would be appreciated.
ATTACH]
[/IMG]
Jason Tyrrell
Highmore SD
The easiest thing take your old one and match thread to a easily sourced hose barb to fit your hose
TXFishin
US
1/4 NPT fitting, or similar? As mentioned, depending on size, a barbed fitting for air, fuel, etc... may work just fine
Sent from my SM-N950U1 using Tapatalk
Drae
Drae
Anchorage AK
Thanks guys! I ended up using a 1/4 npt fitting that was threaded on both sides, a couple inches of 5/8 hose and and a fitting in between the 3/8 hose and 5/8 hose. It's working fine so far. I couldn't find a barbed fitting in the parts stores or Lowes here in Anchorage. Just terrible availability on a lot of parts here. Thanks again for the input!
M Bennett
