3rd Expyowner123
2018 Expy 800 miles, became disabled after stop at local store. I started vehicle, shifted into reverse, message appears on the instrument panel, select shift error. Rotating the shift dial, the red indicator would move to gear I selected while flashing on and off and would automatically return to park. The transmission would not physically shift into reverse, neutral or park. Called Ford Roadside Assistance, who dispatched flatbed truck for tow. Next problem- Could not shift transmission into neutral to pull up on the bed of the flatbed truck. After a phone call to dispatch, the tow driver opened key fob, inserted the actual key into slot inside console and pushed the start button to start the engine. This action cleared the error and once again the vehicle worked normally.
I set service appointment at a more convenient time and will have the dealer review. This Expy was built in early April, after the transmission recall. Think it might be hard for the dealer to detect the root cause of this problem, which if happened one time, obviously could reoccur.
