Trouble with towing. Need advice
chuck s
That's a common misconception (sounds so kinder than "flat wrong). :)
Level is a symptom of proper weight distribution but just 'cuz it's level doesn't mean it's right.
Both suspensions must compress equally on the tow vehicle. That's the goal -- weight distribution not leveling. Makes no difference if the truck and trailer are level if the suspension on the truck isn't taking the weight. Get the truck right, then make the trailer level by adjusting the ball height. Since this will probably change other settings do it again and fine tune it. I've never seen it done right in less than a couple of hours.
-- Chuck
Tim Fuller
Upstate NY
We made a similar switch last year. 1500lb pop up to a 6100lb hybrid TT. Tongue weight going from about 150 to about 610 lbs produced a noticeable bounce for sure. I'm inclined to say it's normal, just different. Definitely check actual numbers and adjust if needed though
cekkk
SoCal
Bouncy, as in front axle? Measure from ground to top of front wheel well both unhitched and with trailer attached. I like measurement to be within a quarter inch of unhitched.
We towed 5000 pounds with an '04 regular length Expedition several hundred miles several times, and it had similar miles in it..
CaptOchs
Rochester NY
Your bars need likely need adjusting. My old bars were chain link and if it was off by one link that was enough to make it bouncy and add sway. Your RV service ctr should have hooked you up letting you take possession of the trailer. If they didn't do it right you ought to take it back.
Where were you driving? Expressway? Last year I had terrible bouncing when I hit this concrete section of the expressway. I swore I lost a bracket or bar so I pulled over. Everything was tight so I continued on. It went away when the road went back to asphalt. I looked it up when I got home and it was some kind of harmonic oscillation effect due to the concrete.
2016 Expy EL
Az
Hello there everyone. We recently upgraded from a pop up camper to a travel trailer in the late fall. Today I was able to take it on the road again and the drive was a bit unpleasant. I can’t really complain about power or sway with the trailer but there was something i did not like. The ride felt very bouncy, so I maxed out the psi on the tires and it did help but there is still too much bounce. I suspect worn out shocks. Any ideas?
2016 Expy EL
Az
theoldwizard1
SE MI
What kind of tires do you have on your Expedition ? Some came with "P" rated tires (passenger car). When you buy new tires, switch to "LT" (light truck).
2016 Expy EL
Az
E rated tires 10 ply would give you a better more stable ride also the Mechanical Leveling Shocks the offered in the Limited and Platinum Expeditions would help.
Fordalways
North Central Texas
I have to assume the dealer set up your hitch with an empty trailer. They should have demonstrated to you how to make the adjustments, but there are likely YouTube videos on this. Once you start packing, it is amazing how easy it is to toss in a 1,000 pounds or more in it. Weight distribution makes a difference. A travel trailer should present 10-15% of the gross weight on the ball. This is necessary for stability. Without this weight on the front end the trailer might seesaw on its axles possibly contributing to the bounce you’re feeling. Without scale weights it’s just a guessing game.
Start as others suggested by parking on a flat surface and switch off the auto leveling if you have it. Measure the height of your front and rear wheel wells then lower the coupler and lift the jack allowing the full weight to rest on the ball noting how much the rear square and how much the front might rise. Attach you spring bars using the jack to assist if necessary, then lift the jack again. If properly adjusted, the front and rear measurements should show a roughly equal drop from the initial measurements; a little more on the rear is acceptable. Once you have this right, adjust the ball height to get the trailer level front to rear. You may or may not have to readjust your spring bars. The Expy and trailer will look reasonably level once you step back and look at it. Once all is set, you can now switch your auto leveling back on.
When you go to the scales, go with the trailer packed as you would for a road trip, junk in the trunk and your passengers, full tank of gas, etc. Consider your travel: If you only go to RV parks with full hookups, you may routinely travel with relatively empty holding and fw tanks. If boondocking, you may go with full fw and return with full holding. Just consider that you may routinely be traveling with some water in the tanks.
When you get weighed, you will get a printout showing the individual weights for your front, rear and trailer axles and a total. You can typically get reweighs within 24 hours for a buck or 2. You’ll want to pull out of the way, unhitch and get just the Expy weighed (with same passengers). You now have real numbers to work with. You can verify that the GAWR for the front, rear and trailer aren’t exceeded nor the GCVWR. And you can see how much is on your front and rear axles with and without the trailer.
For math simplicity let’s assume your 6800 lb trailer is loaded with 1200 lbs of gear, groceries, water, etc. and now weighs 8000 lbs and has a tongue weight of 900 lbs (11% TW). The WD hitch should distribute 300 lbs each to the front, rear and trailer axles. If you end up with 250 on the front and 350 on the rear, that’s not necessarily bad as long as you’re not overloading the rear and your low beams aren’t scanning the trees.
If you find that the weight distribution is still way out, you may need to refine the adjustments and go over the scales once more. Once you’ve got this set, you shouldn’t have to do it again until you trade the Expy or the trailer or for some reason change out the hitch.
As previously suggested, replacing stock P-metric tires with LT may be beneficial also.
Concrete expressways can be problematic and most noticeable with a trailer.
http://www.thedieselstop.com/forums/f32/freeway-hop-42513/
There are numerous factors that determine whether it is a soft porposeing motion or a teeth jarring event. Freeway hop is a well known phenomena and opens lots of discussion about speed, wheelbase, trailer length, suspension mods, etc. in over 30 years of dealing with this, the only thing that has softened, but not eliminated it is an AirSafe hitch. Getting your tongue weight right for your trailer and properly adjusting your WD hitch is the most you can do.
SailorKane
Florida
I did the same thing some time ago, at about the same mileage. I had a 24' TT, so your 29 is probably at the max you could tow. I had Different brand WDH (Reese, IMO the best WDH on the market). Went to a scale, weighed the truck alone first. Then weighed each axle of the truck and tow without the WDH doing its weight distributing. Then set it the WDH up and weighed it again. It was better, but still not right. I adjusted the hitch, increasing the tension, until it was right. I suggest you do the same. Sounds like you may have too much weight on the tongue, increasing the pressure on your back tires and suspension, and the WDH not doing enough. But you will know once you weigh it. Cat scales at a local Loves or Flying J is like $10. Whole process is a couple hours. Be sensitive to trucks needing to weigh during the process.
