Unusual Noise
04exped
florida
I have a 2004 expediton 5.4L
there is a noise coming from underneath of it, its not real loud as in the guy next to me can hear it. Initially i thought it was the hub bearing and so it went to ford dealership and the said it was the right front hub bearing. I replaced it but the noise continues. I am told that it may be the front differential but how does it go bad? I was considering disconnecting it, but by the wheels still being connected i don't think it would do any good.
Any suggestions?
i am new to the site and just looking for help.
metaldrgn
somewhere
Need more info. Is this noise just occurring while in motion? At a certain speed? Can you describe the sound?
04exped
florida
no air suspension.
the noise is more like gears turning, like and air plane eeeeern??
at 20 mph is when it starts and continues. only when in motion although i have not tried it in reverse.
metaldrgn
somewhere
Could be a wheel bearing then. There was someone else who had a similar problem, maybe search for it, and it ended up being a rear wheel bearing. Differentials will start whining when they don't get proper lube (that's the primary reason anyhow).
Does it sound like a whining or more like a grinding noise?
04exped
florida
Hope this helps someone else
it turned out to be the front diff gear box.. and the electronic component that uses a vacuum i believe to engage and disengage 4 wheel drive. i really hope this helps someone else.
the noise is completely gone now..
